Discuss To seal black floor grout or not? in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Spud 22
Hello all, I have recently laid ceramic tiles in my hall, bathroom and kitchen(all the same tile) I have used Mapei black grout.
I have never sealed grout before but because it's black grout I was considering sealing it because of fading?
Any recommendations please?
Tile Fix Direct
TF Official Sponsor
Does the grout fade, or does dirt and limescale sit on the surface and make it look like it has faded? Dirt and contamination on dark grouts (not in them) will always appear lighter and could give the effect of fading. If this is the cause of 'fading' then sealing is not the issue but cleaning.
J Sid
as above, it's normally a bad cleaning techniques that makes grout change colour after install.
Waluigi
Would sealing the grout in the first place not help to aid cleaning?
I offer sealing on all floors these days, in particular the whites, blacks and jasmine.
Tile Fix Direct
TF Official Sponsor
You would have thought sealing grout would help cleaning, but it might have unintended consequences. Depending on the sealer it may prevent the grout 'breathing' which could result in salts/moisture building up behind the sealer and discolouring the grout. Different grouts/sealers and substrates could all have different effects. Best contact the grout manufacturer.
Spare Tool
Agreed, a customer of mine absolutely ruined there grout in the space of a couple of months using a steam mop on the floor..
Waluigi
Also depends on the grout texture. A smooth grout sealed will stay far cleaner than a sandy grout sealed in my experience.
Italy
if it is ultracolor plus black, it does not need anything.
Spud 22
Hi.its only been down a few days and looks fine now. I just want it staying that way.just wanted to know if sealing grout was common practice?
Reply to To seal black floor grout or not? in the Adhesive and Grout area at TilersForums.com
Dawz84
