Discuss Split Face Stone tiles - best sealer to use? and when to seal? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Albert
I agree, my logic was to mechanically fix 4mm Marmox boards through to the brickwork, but the tiler disagreed and says the weight will be taken away slightly as we are tiling from the floor boards now rather than from the skirting board!
James does it tell you weight on the box or did the shop you bought from tell you the weight?
Matt V
That's complete rubbish you cannot rest the tiles on the floorboards and tile. You need an expansion gap. Weight would be far too much for those walls needs overboarding as you said
Waluigi
4mm Wedi.
Score the living daylight out of the paint. Prime, tile adhesive and screws/washers. Not a lot of money the foam boards these days. Not worth the risk
Boggs
It’s a small outlay and an hours work or maybe your tiles will fail and you start again.
I know what I would do.
James C
So I need to insist the tiler buys boards and spends time fixing them properly? It’s difficult arguing with “an expert” with a load of 5 star reviews that I know better!
5 Star ratings?
May I ask where?
It certainly wouldn’t be from on here.
If argues the point, I’m sure this information on tile weights is on the TTA website.
It’s on here too, but who are we to argue.
James C
I’ve just realised the tiler we have booked in is a member on the forum...
We are on such a tile schedule now I’m not sure we are going to be able to find another, we need the tiles fitted in the next 9 days and I’m sure everyone is fully booked :(
Reply to Split Face Stone tiles - best sealer to use? and when to seal? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Apatel
