Discuss Tiling around door frame in the Canada Tile Advice area at TilersForums.com.
Boggs
1,118
Uk
I would take down the jackoboard on the stud work and refit but sticking it with some rapidset.
Screw back through your studwork and fix again using some spring toggle fixings midway between the studs leaving you with a 200mm centre fixing.
Best be safe than sorry especially with that size/weight tile.
James De
588
London
You’re totally right. Can’t say I’m not gutted as I’ve tanked the wet area now. But I like sleeping at night so I’ll do what you’ve suggested and just retank the joins when I’m done. So stressed I need to finish this job by Sunday.
Waluigi
On the plus side, you’re learning.
I know you posted a thread on this before you did the work. Did none of us mention that it needed gluing?
James De
588
London
unfortunately not.. I’d have glued it if I knew.. oh well. A lesson learned. Again haha
Boggs
1,118
Uk
If it’s already tanked why not just reduce the spacing with spring toggle fixings.
Combined with the washers this will give you a really good strong fixing to the background.
James De
588
London
I think I love you man haha good idea I will do that. Thank you..
Boggs
1,118
Uk
No point rushing it, the only thing to be learnt by rushing is to cut corners and make mistakes.
James De
588
London
Would you use toggle fixings over hollow wall anchors?
Reply to Tiling around door frame in the Canada Tile Advice area at TilersForums.com
  • Poll
