Discuss Tiling around door frame in the Canada Tile Advice area at TilersForums.com.
James De
588
London
hi everyone..
So doing this wetroom.. have boarded the walls with 6mm jackoboard. Have boarded around the door frame and left the timber frame exposed.
So the board sits proud of the frame, as will the tiles.
Is it best to tile to the far edge of the door frame or up to where the frame begins?
Also, are there edge trims that will hide both the edge of the tile and the cement board?
Cheers in advance
Jay
WetSaw
Is there not architrave going on? If so just add the correct thickness of wood to the frame before fitting the architrave.
James De
588
London
I’ve no idea to be honest. So should I tile up to where the frame begins then so the chippie can finish off? (Assuming he’s fitting architrave)
acaciaguy
558
Warwickshire
I would find out both. The more information the better so you can get your bit right from the start :grinning: it's those finishing bits around doors etc that make or break the finish of a job
Boggs
1,118
Uk
Find out your architrave width and add 5mm.
Time's Ran Out
6mm backer boards are a bit thin! Did you stick it and mechanical fixing and what was the background - studs or plasterboard?
Reply to Tiling around door frame in the Canada Tile Advice area at TilersForums.com
  • Poll
