Which levelling system
If I can find the time I have 110m(2) of 60x60 porcelain floor tiles to lay. This would be the largest are I have done. I have never used tile leveling spacers but thought I might try them out. Any recommendations? I'm thinking of my namesakes system but I know there are lots of alternatives out there.
I picked up some screw levellers recently as I also have some 60x120 wall tiles to fit, only 12, but I'm tempted to take them back.
with that last name you should not ask yourself questions 🙂
I haven’t used the screw levelling system but I’ve heard they can scratch polished surfaces?
Which ever levelling system you use, use a clip smaller than your grout joint so it will be easier to break off and not chip a tile.
I took the plunge and ordered an Italian system from Amazon in Spain. Cheaper than buying it here in Italy unfortunately. And I had a small credit to cover the postage. I did consider getting the 3D but wasn't sure it was worth the difference in price. Why don't they do 2mm clips I wonder?
Do they work well? Cost asides are they worth using?
quanto li hai pagati?
lasciaperdere i 3d , troppo fragili
Paul Giovanni Raimondi,
Italy,
Italy,
