Discuss No More Ply for laying 600x300 porcelain in the Australia Tiling Forum area at TilersForums.com.
On one
One 12mm layer will be cheaper and quicker than two 6mm layers.........if it was even needed in this case,which seems doubtful!
Looks like overkill and added difference in height to the floor
H
hmtiling
Around £9 a sheet and £7 per tube of pu glue. Their self tappers also £7 for 200
Colo
233
Durham
Cheers for the help lads. The reason I wanted to double up the 6mm is that it is much more dense than the 12 mm and I thought it would give a stronger floor.
Another option would be to put 12mm ply down and tank it. Does any one still use ply.
Cranbrook
598
Pontypridd, South Wales
No tiling on ply is a thing of the past.. if you are happy with the additional height, just put one 12mm NMP down and you'll be sorted, but as others have said, if you dont need the height, one 6mm NMP should suffice
H
hmtiling
If you really want to strengthen the floor go with permat. It gives a 10 year deflection warranty
Reply to No More Ply for laying 600x300 porcelain in the Australia Tiling Forum area at TilersForums.com
