Discuss No More Ply for laying 600x300 porcelain in the Australia Tiling Forum area at TilersForums.com.
Colo
233
Durham
Hello,
I am planing on using no more ply over my existing 18mm flooring to lay 600x300 porcelain tiles.
Would there be any benefit in laying 2 layers of the 6mm no more ply to create 12mm covering.
Will this make the floor stronger or is the 6mm enough.
The joist are 8x2 at 16inch centres with a span of 10ft. There is no noticeable deflection when tested with a laser and the 18mm floor is in good condition
Any advice is appreciated.
H
hmtiling
Hello,
6mm nmp will add a bit of strength to the floor which i'm assuming is chipboard. 2 layers will definitely add more strength. depending how bad the deflection is i'd consider adding noggins and more fixings or using Blanke Permat.
On one
It doesn't follow that two layers of 6mm would necessarily have the same strength as one 12mm board.
Two 6mm layers might be stronger,but no need to double up on NMP.
If you double layered you could overlap joints of first layer with second layer . Got to be some merit in that
Cranbrook
598
Pontypridd, South Wales
Hello,
Just checking but you do realise you can get NMP in 12mm rather than having to put 2 layers of 6mm down?
H
hmtiling
Id say only marginally, and with joists at 400 centres like the Op has then 12mm boards would be sufficient, in my humble pinion of course :)
Actually, if you read nmp's literature then you'll find that overboarding with 6mm and 12mm adds the same strength according to them. Cross laminating them would add far more strength in my opinion. To strengthen the floor permat would be the way to go
H
hmtiling
Reply to No More Ply for laying 600x300 porcelain in the Australia Tiling Forum area at TilersForums.com
