Discuss First tiling job after my course with UKPTT in the Tiling Courses area at TilersForums.com.
James De
588
London
Thank you to everybody for all your help, it’s much appreciated. I’ll post some pics once I’m done, unless I completely F it up that is :D:confused::eek:
James De
588
London
So...
I boarded all the walls today (pretty much every single bit of render collapsed so had to board every wall).
The brick was so uneven I tried my best to get the boards even (CTD only had 1200mm boards in so had to jigsaw a few together) but on some of the joints there is a couple mm difference, and where the boards meet the good render there are lips and dips.
What’s the best thing to do to even everything out? I’ve had to feather one wall with adhesive as there was a massive dip between boards.
Thanks in advance!
Waluigi
If you’re meeting boards against render on the same wall then there is your issue. It might’ve been better to spend extra time and hack off every last piece of render and board the lot. All you can do is use Adhesive to flatten things up really.
When doing the prep with tiling it’s important to spend the time prepping everything perfectly because even small things that aren’t quite right can become quite large compromises once you reach the tiling stage.
If you haven’t already then get yourself a featherdge or two. Level things off nicely. I’m sure it’ll be fine. All the best
James De
588
London
Yeah I’ve got a feather edge. I’ll spend today sorting it all out. Cheers Walugi
James De
588
London
Any pics ?
Ok.. I’m prob gonna regret this but here goes :eek:
E1D45F4B-CE3E-49D0-972A-88DDAA7964CA.jpeg C0AA9F3E-6677-441C-B42C-2AA832200CDD.jpeg A0E248C2-4659-42D2-A336-17BEF9517D01.jpeg
Reply to First tiling job after my course with UKPTT in the Tiling Courses area at TilersForums.com
