Discuss Leveling floor with cement board in the Canada Tile Advice area at TilersForums.com.
average
508
Uk
You have just made the statement that it can’t be used and now you are suggesting it can be.
Nmp say you can and hardie say you cannot. There’s no point using either on a solid floor anyway when insulation board it better easier and cheaper
How is insulation board better than NMP. Is NMP not more solid than insulation board.
Bond
518
Highland
Cement reinforced faced insulation boards, prime floor, use flexible adhesive to bond to floor, stagger board joints and fix scrim tape. In addition you could core holes staggered across the board adhesive will lock boards in position, you may also need to weight boards until adhesive sets. When adhesive sets you could add additional fixings into concrete although probably not necessary. Good luck.
Bond
518
Highland
Not quoting from a manufacturers specification particularly, just successfully method l have used /adapted in the past.
average
508
Uk
TY
Never had a board let go without coring holes into them .
average
508
Uk
This is such a confusing read from start to end.
Be quicker to & better to self level. No faffing about then.
I can't get to it untill Wednesday now. I will be using the insulation boards and self leveller in parts. The time I have to finish this is short. How soon can I tiles over the boards and self leveller. Can I tiles as soon as it walkable on.
Reply to Leveling floor with cement board in the Canada Tile Advice area at TilersForums.com
