Ive to tile 2 floors that are in 1 room with a dividing wall half way across the middle however im in a tricky spot and with floor levels. Its an old house and floors where in a bad way. In one room ive grinded it down all flat and near level as i can get it. Theres also an inch step into the other room where the floor levels are bad. If i put my long level on the step and the other end of the level resting on packers that are 15mm on the floor, its reading level. Then level over to the screed at the front door, its reading level.
I usually use nomoreply for leveling however my local store only has 6mm NMP untill after xmass. IS it ok to use cement board at 3/4 inch instead. Im not to sure as ive only seen CB used on timber on first floors and never onto screed.
