Discuss Leveling floor with cement board in the Canada Tile Advice area at TilersForums.com.
F
Flintstone
Why no Hardie backer. Is it because you've read it somewhere as well or actually know why? If hardie is installed on to screed with flexi addy then flexi addy used above then why not if aloud on top of a timber floor with ply.
You have just made the statement that it can’t be used and now you are suggesting it can be.
Nmp say you can and hardie say you cannot. There’s no point using either on a solid floor anyway when insulation board it better easier and cheaper
H
Handyeire
I have been just going on what I've read online however I've know of some who have used it. Not myself thou.
What if one can't get the insulation board. NMP should do ok but I wouldn't build it up just in case.
average
508
Uk
How is insulation board better than NMP. Is NMP not more solid than insulation board.
Bond
518
Highland
Cement reinforced faced insulation boards, prime floor, use flexible adhesive to bond to floor, stagger board joints and fix scrim tape. In addition you could core holes staggered across the board adhesive will lock boards in position, you may also need to weight boards until adhesive sets. When adhesive sets you could add additional fixings into concrete although probably not necessary. Good luck.
Reply to Leveling floor with cement board in the Canada Tile Advice area at TilersForums.com
