Discuss How to tile an internal corner in the DIY Tiling Forum area at TilersForums.com.
If you've got grout in the joint at all it won't allow for movement . Now we are not talking about the integrity of the joint but the the stress it can put on the rest of the installation . You are meant to have a movement joint between two abutting surfaces .
Bond
518
Highland
Bond
518
Highland
In the situation discussed the grout is only cosmetic ,(on the surface, ) any movement, the grout will crack and fail, without comprising the integrity of the joint.
Once had a customer say, when l had finished a shower, “what’s that in the corner” it’s silicone sealant ( normal practice in the situation) bla,bla,bla, . “Don’t like it , get rid of it, l want grout”
Yes mam, using a double edge blade cut the silicone back to the corner , and grouted over to conceal the silicone. No problem.
If that’s what the customer wants.
As I said it's not just about the integrity of the joint you are meant to have a movement joint between two abutting surfaces to stop the installation getting stressed by movement between the two surfaces . Even In a dry corner it should be silicone to allow for movement between the two surfaces .
Bond
518
Highland
Bond
518
Highland
As detailed above the corner has been silicone, the grout is only cosmetic not structural in any way, and as such will not hinder movement.
Reply to How to tile an internal corner in the DIY Tiling Forum area at TilersForums.com
