Discuss How to tile an internal corner in the DIY Tiling Forum area at TilersForums.com.
Bond
518
Highland
sorry, i do it on internal corner walls of showers, if one wall is a stud wall,it seals the corner, it and i'd rather look at grout in the corner instead of silicon.
Similar situation to doing external rendering/rough casting around window/door reveals where some will sandwich silicone sealant between the scratch and top coats, it ensures the seal movement joint is encapsulated. Then finish with an additional seal on top. I guess it’s down to what you have been taught. Preference etc.
248
northern ireland
yes but i have found that if the grout does crack then the silicon in behind stops the water penetrating, and i've went back to showers years after having used this method and and the silicon helps to stop the grout in the corner cracking. also no one wants to look ak a newly tiled shower with silicon in the corner, no matter how well the silicon is fitted.
Bond
518
Highland
I personally don’t have a problem with your methods, if that’s the way you do it, and it works, don’t be put off by what others might say.
What do you do with floor to wall joint and other internal corners out of the wet area ?
Time's Ran Out
I do internal corners of shower areas and along baths with a double bead of silicone.
Reply to How to tile an internal corner in the DIY Tiling Forum area at TilersForums.com
