LTP Grout sealer and protector
Spare Tool
Just grouted a floor today with TM Jasmin, against my advice of it being too light a colour thats what she wanted, anyhow picked up a can of LTP grout sealer spray...is it any good, also is it as easy as it says on the tin, just spray and leaves no residue on the polished porc?
Did a test on some kitchen roll sprayed and the water wouldn't soak into it at all, just sat on it in a droplet, so definitely improves water penetration, which in turn has got to surely improve staining etc..
Am popping back tomorrow night to seal the grout so can I just spray over joints and walk away confident or should I need to hang around and polish up?
Oh and somone will no doubt mention epoxy...don't bother 😀
If over applied, can leave residue thats difficult to shift. Depends on the tile as to how visible it is. E.g black polished porcelain shows everthing, even that what shouldn't be there.
Cheers Paul these are the tiles if it helps...Simpolo, vitrified polished porc? WP_20170220_15_32_22_Pro.jpg
Have you had a good deal on wedge clips or something?
Funnily enough yes I have but mainly used so many as the tiles are 800's and they're having plinth lights across the floor which will illuminate the slightest of lips so just being over carefull 😉
I have recommended this to plenty of customers, I advise them to spray it into the lid and apply it with a paintbrush to the grout lines, saves on having buff tiles and it lasts longer
Best way to use ltp grout sealer is to spray on leave a few minutes then a quick buff with microfiber cloth especially high gloss tiles.
Biggest mistake made is holding can to close to joints, should get around 600 linear meters to the aerosol if instructions are followed, also they do a liquid version in 1ltr bottles for large area's.
Spare Tool,
ltppebbs,
Spare Tool,
ltppebbs,
