Waterproof tape
R
ROCKER21
Hi
Can any one advise me please, I am building a shower and have just brought some ORBRY waterproof tape for the joints.
It arrived today but no instructions .It is not self adhesive so requires something to stick it to the plasterboard.
It is like a fibre glass with a central section of rubber one side. Which side goes against the wall .I will be appling Aquseal
waterproof membrane over it. Thanks.
:welcome:
If you are using a liquid type membrane with the tape, then just coat the corners/ joins then overlay the tape then coat over. Very easy to do :thumbsup:
Hi
have you read the instructions with the tanking. There you will find your answer.
I use somethink like the bal tape and do it directly to the tray then paint the walls with WP1....
Waterproof tape
ROCKER21,
White Room,
ROCKER21,
White Room,
