Dealing with rusty screws
V
vrytir
Hi,
because of my strawboard wall, I had to use screws which had coarsed thread for instalation of tile board. I tried to waterproof it by putting some marmox acrylic sealant on it. And now the screws are starting being rusty. What should I do to avoid the later rusty colour in grout. Thanks for your help
change them to stainless steel ones?
The problem is the straw wall on which I installed the boards. Because of this I had to use the screws which I used (with big thread). I used flexible adhesive to stick boards on the wall and then just to make it stable I used the screws(quite lots of them). So the adhesive is solid so I do not want to take the screws out.
Is it going to make the problems?
Paint them with epoxy. This will stop the rust coming through.
I was thinking more along the lines of the rusty screws "shearing" after time Alan:smilewinkgrin:
I was thinking it will just be the heads oxidising thanks to the acrylic primer .....l. Unless there is a much bigger problem. Would have used galvanised screws myself but hey ho...... Valid concern though 🙂
does acrylic primer do that to ordinary screws Alan? i didn't know that, but I do now:thumbsup:
Any epoxy primer will do the job. Merlin coatings do one called barrier coat which is reasonably priced but you could probably pick one up on eBay
vrytir,
Ajax123,
vrytir,
Ajax123,
