Coloured 'Glass' Mosaics
A
AP Tiling
Will be doing my first job with these tomorrow, just a kitchen splashback but how do you go about spacing/cutting them.
I havent seen them yet just going off what the customer said but would like to be prepared for the worst.
Thanks.
This is your adhesive for glass
BAL Mosaic-Fix Tile Adhesive
A bright white, non-slip, water and frost-resistant, cementitious wall and floor tile adhesive specially formulated for fixing mosaic tiles including glass mosaics. It is also suitable for fixing ceramic wall and floor tiles, metal or glass tiles, marble, terrazzo, and natural stone in interior and exterior locations. Suitable for use in swimming pools. Can be used on most surfaces including MDF (in internal dry areas).
and grout should be polymer modified to stick to the sides
BAL Superflex Wall Grout
A brilliant white, water & frost resistant cementitious wall tile grout with built-in admixture to give increased flexibility and high bond strength. Suitable for grouting porcelain, marble, natural stone, glass and ceramic mosaics, glazed and fully vitrified tiles. BS EN 13888 CG2 Grout.
As regards cutting use fine blade wet saw,if glass face spelches then cut from rear.....always wear protective eyewear....Gaz
Thanks for that. One more question, I am told these mosaic strips are tiny, around 15mm per tile, surely impossible to wet cut......
NIGHTMARE TO CUT
Ihave found wetsaw no good, try and score and snap with cutter or nippers.
Try and space so minimal cutting or with cuts into corners.
Try and adjust spacing during setting out to avoid cuts - takes more work , but increasing your spacing on a few grout lines by a fraction of a mm or so over a couple of metre length will hardly be noticable and may be the difference in having do do a cut or not !!!
NIGHTMARE TO CUT
Thanks for that. This was what i was thinking, space out and try to avoid any cuts, i think im going to run into problems as i have just had a look at the walls and there is 6 sockets, lots of ridges, corners and a window ledge. :mad2:
first job ...glass mosaic....... n loada sockets
thats jumping in at the deepend
if yeah feel unsure,might be wise to let the customer know
or maybe get custmer to change tiles
havnt had any agro cutting with wet cutter....glass brakes at back when cut with nippers n shows when fixed
:ninja:
You need to look at things like this at quote stage !!
It is unlikely that I would have even taken this job on with glass mosaics, no matter what the price - too much hassle - too much likelyhood of cuts looking crap !!
Would rather sit at home for a day and watch Jeremy Kyle with a can of Stella or 2 !!!!
AP Tiling,
Leatherface,
AP Tiling,
Leatherface,
