Discuss Which Mapei Adhesive for 10mm Large format porcelain tiles in the America Tile Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
A
ap222
Hello, laying down 44mm x 66mm porcelain floor tiles on perfectly level floor. which adhesive shall I use? Mapei Keraquick or Keraflex?
Datasheet for keraflex says surfaces ready for use in 14 days, do you have to wait that long, its a bathroom floor.
Any guidance appreciated. Thanks
The Legend; Phil Hobson RIP
You are very luck mate, you must have the only perfectly level floor on the planet. I have been searching for one of these for 43yrs, to no avail.:lol: as Dave above we need to know the substrate:thumbsup:
A
ap222
It depends on how quick you tile..?
What substrate do you have..?
Its joists, 18mm gyproc flooring boards, 12mm ply on top of that, 10mm marmox insulation boards, ufh & levelling compound. All timber screwed down at 300mm centres.
A
ap222
Sorry Phil, you're right, what I mean't was near enough smooth & flat surface, due to the levelling compound....:smilewinkgrin:, perfectly level it ain't....there are deviations on the floor when putting a straight edge to it...
I'm a newbie to tiling, so I'm pretty slow. apart from the setting time, is there any advantage of using Keraflex over Keraquick?
Keraflex has a pot life of 8 hours, and an open time of 30 mins. Keraquick is a rapid set, giving you less time to adjust tiles. I would go for Keraflex:thumbsup:
Reply to Which Mapei Adhesive for 10mm Large format porcelain tiles in the America Tile Forum area at TilersForums.com
Lowpaul22
