Discuss wet room tanking height in the Canada Tile Advice area at TilersForums.com.
I
ivorbigun0
Hi all
I have a quick question for you.
Im having to strip out a leaking wet room which was done using a tile safe membrane that had been cut at floor level causing the leak.
Im going to remove the floor tiles and re membrane with a 75mm up stand up the wall. The walls are cement board 12mm and was wondering if these walls need to be tanked and to what height?
Many thanks
Ivorbigun0
Reply to wet room tanking height in the Canada Tile Advice area at TilersForums.com
