Discuss Weight of Porcelain in the UK Tiling Forum area at TilersForums.com.
Richardk
Could anyone help me with a guesstimate of the weight of a glazed porcelain tile 600 x 400 x 10.8mm of Spanish manufacture? I think it will be too heavy to fix onto plastered bathroom walls.
Richardk
Thanks. I have put one on the scales and I reckon the total weight with adhesive and grout to be about 28ks/m2, so 40% over the BS guideline. The feeling at home is that the scales weigh under which not only adds to the tile problem, also means I'm heavier than I thought :oops:
CJ CERAMICS
lol :lol::lol::lol:
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
put up some 6mm hardie backer board on the walls..this will take the weight.
He did say his walls are plastered already mate. The weight of the hardi AND the porcelain tiles would be more than just the tiles alone in this case so it's not a fix using it. Or am I reading something wrong?
DHTiling
As long as you can machanicaly fix as well then that is an option....hardi will not work if no fixings used as it is adding weight as Dan stated.
White Room
Just a guide Tiles and Adhesive Weight Per Square Metre - THE TILE SOURCE
Reply to Weight of Porcelain in the UK Tiling Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
