Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Weight of Porcelain in the Tiling Standards area at TilersForums.com.
C
CJ CERAMICS
Thanks. I have put one on the scales and I reckon the total weight with adhesive and grout to be about 28ks/m2, so 40% over the BS guideline. The feeling at home is that the scales weigh under which not only adds to the tile problem, also means I'm heavier than I thought :oops:
lol :lol::lol::lol:
Dan
Admin
5,085
1,323
Staffordshire, UK
put up some 6mm hardie backer board on the walls..this will take the weight.
He did say his walls are plastered already mate. The weight of the hardi AND the porcelain tiles would be more than just the tiles alone in this case so it's not a fix using it. Or am I reading something wrong?
DHTiling
As long as you can machanicaly fix as well then that is an option....hardi will not work if no fixings used as it is adding weight as Dan stated.
DHTiling
HardieBacker EN installation 200810 masonry walls.pdf
tfs
To the best of my knowledge Knuaf say that there aquapanel can be used with metal and timber studs, however, timber and metal studs are normaly spaced at 400mm centres on a stud wall however on some occasion you will find that this can be as much as 600mm with noggins/ dwangs centred in row roughly at the centre of the vertical studs which is realy not ideal as this leaves unsupported boards on an area of approx 1200mm x 360 (between all studs)
To add extra fixing at lower spaces you would realy need to rip off exiting sheeting and add extra framework to the partition adding an additional two noggins (one above centre noggin and one below) in between each vertical stud. This would give you extra fixings at smaller intervals and should give a far superior fixing to the stud work. I would preffer to use 12.5mm as it would be harder to come away from the studs than 6mm would.
Reply to Weight of Porcelain in the Tiling Standards area at TilersForums.com
I will be tiling with 60*30 procelain tiles. They weight about 3.57kg each which is about...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Weight of Porcelain
Tiling Standards
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
