Discuss Underfloor Heating In Wetroom Showerscreen in the Tanking and Wetrooms Forum area at TilersForums.com.
C
Craig Hamilton
hi just wondering if u can run underfloor heating under a shower screen I know u can't put it under cabinets, toilets ect but wasn't sure about a shower screen thanks in advance guys
craig
H
hmtiling
It can go under anything as long as it's not drilled through and is covered with slc/adhesive and tiles.
H
hmtiling
be careful how close you go to the trap and what watt per m2 is compatible with the tanking.
C
Craig Hamilton
The closest I have went to the trap is 40mm is that to close? Thanks for the help guys
H
hmtiling
It's different for different systems. 40mm does seem a little close to me, but check with the manufacturer.
H
hmtiling
150mm springs to mind but not sure. I'd check with the supplier to be safe and not void any guarantees
C
Craig Hamilton
Wow that a fair distance my tiler is coming tomorrow so I better try and sort it quickly is it the trap manufacturer I should check with is this because the heat can damage the plastic?
H
hmtiling
I don't think it would damage the plastic. I think it may be to do with heating cooling round the seal/grout at the trap. I'd try whoever you got the wetroom kit from first and if they don't know try the manufacturer of the trap. Good luck
C
Craig Hamilton
thanks hm called the manufacturer and you were right 150mm thank you so much I managed to move it about 130mm so I'm happier with that I will replace the seal annually :)
Reply to Underfloor Heating In Wetroom Showerscreen in the Tanking and Wetrooms Forum area at TilersForums.com
  • Poll
Hi Guys have a big gap above tray to fill 2cm high 1cm deep (3/4in x 1/2in) Any suggestions...
