Tiling on underfloor heating warm panel
Hi all,
I've put water underfloor heating down in our bathroom using "ProWarm Warm panel" which are panels with premade tracks for the pipes in wet rooms. The panels are glued together but not glued down (consistent with manufacturers instruction) and with plastic end panels which enables the pipe to turn back - these are screwed down to the plywood. I found it strange that the warm panels are not glued/fixed down, any comments would be appreciated). Under the panels I have 18mm PLY on top of wooden joists with kingspan in between joists.
Apparently the UFH panels can be tiled onto directly - however the company that sells them recommends a 6mm ply to be used between boards and tiles - this sounds strange to me but I am a bit scared tiling directly as well as the pipes are exposed so could be damaged by mistake.
To summarise:
  • Is it strange that the panels are 'floating' on the plywood and, if so, how would you fix them?
  • Would you tile directly on top of the UFH boards? If not, what would you put on top and how would you fix it?
Many thanks,
Jon
Do not put ply on top, that would be contrary to British Standards and is likely to fail. To tile directly onto the panels you would need to get a specification direct from an adhesive manufacturer. Try Building Adhesives, Kerakoll, Ardex or Norcros. You might want to prepare yourself for bad news!
We just had a thread on our electrical forum about ProWarm.
Every manufacturer of electric underfloor heating wont honour a warranty unless it's connected by a Part-P certified sparky. There's a sparky that found a supplier who would honour it even if the homeowner did it.
We had several suppliers on the forum saying no way. That's void. How can we trust the homeowner, where is the line drawn. Kinda thing.
Turns out it was ProWarm.
Seems they're flogging anything to anyone for any spec then by the looks of it!
Plywood has no use in any building trade these days. It isn't the solid wood it used to be.
EandOE.
p.s. I know this is water in your case - but it was the same supplier, electric in the other case. Hopefully if you have an issue they do actually honour their warranty.
You don't need to glue them do it your putting a wooden floor on top. I seen this done and was terrible.
For your size of floor I'd take it up and glue it down, refit pipes, uncoupling membrane and tile
[automerge]1569950364[/automerge]
Just seen your pick of the one you have. No my choice but have seen them used. Screwed down every 300mm onto wooden subfloor
What's the black stuff it's actually fed into? Is that like a poly/plasticy type material?
Hi guys,
Thanks for the responses. Sounds like I’ve not chosen wisely. What are my options here? I cannot completely reroute the circuit as I have already fitted floors in neighbouring rooms so the pipe length is set. I could perhaps carefully remove the warm panels and replace with something else bit would need to keep the layout of the pipe.
Any tips on how to solve this would be really appreciated.
I’ve not tiled to these systems but looking at that spec , turns it’s a floating substrate, it’s a no from me.
But As said above , fixing to substrate has to be done but always check adhesive suppliers spec/ warranty.
As Julian said above, just screw boards down to floorboards every 300 mm
These retro fit systems are often loose laid but boards glued together.
Typically the combined weight of boards pipes water and tiles is enormous, and movement isn’t expected, but always possible, hence mechanically fixing boards down.
From there, there are two recognised routes.
Either Ditra 25 and tile or
Pressurise system to 6 bar cold, cover with self leveller to 5mm over pipes, when leveller is cured release pressure and this will give small amount of space for pipes to expand and contract during heating.
Then cover with a 1mm antifracture Mat, such as time master and tile.
Tilemaster will spec tiling direct to the board with their ultimate S2 adhesive, but they prefer latex and antifracture mat.
Just make sure you use recommended primer on top of boards before any work commences.
And prime the leveller before tiling if you take that route.
They’re not a real concern if correct procedure is carried out.
The ones to watch are the polystyrene foam boards with aluminium foil on top, they’re bad news and originally designed for laminate, not tiles.
Thanks for all your responses. The way to move forward for me seems to be fixing the boards down to the 18mm ply. As the floor is level already I will probably not use self levelling compound on top if not necessary.
The manufacturing instructions then say:
“The boards must first be primed using Prime IT MSP. The tiles can then be secured on top using a suitable S2 flexible tile adhesive.
This seems to be consistent with what is recommended here. Would it make sense to put an antifracture mat on the boards before tiling?
Finally, I realise I am in well over my head trying to tile this myself so if anyone is or know a good tiler that fancies quoting for the job please let me know. We’re in London N16. Apologies if this is considered bad manners on the forum.
Many thanks again for all the answers!
It’s not bad manners Jon you’re fine.
If you would like to try and find someone suitable please start a new thread in the
FIND A TILER section.
Thank you.
[automerge]1570007874[/automerge]
Incidentally the leveller is not actually for the purpose of levelling the floor.
It’s prime purpose is to fully encapsulate the pipework, whether it be adhesive or leveller, it must be done, and to allow for a good even transfer of heat between pipes and finished floor.
Also be aware that the first time heat is put thro the pipework when the floor is tiled, it must be taken thro the proper warm up and cool down process first, before normal use.
The purpose of this is to reduce the risk of thermal shock in the adhesive.
And if in the future it’s ever turned off and on, thro summer months for example, it must be turned off and on over a few days, slowly reducing or increasing heat. 2-3 days would be sufficient.
Thermal shock can happen at any time there is a fast change of temperature.
Like putting boiling hot drink on cold granite can crack a cup.
Nothing to worry about, just something to be aware of.
Thanks for the clarification - that makes complete sense.
I suppose it does not make sense to use an antifracture mat if not using self levelling compound then? Is that right?
I'll post in the find a tiler section shortly. Thanks for pointing me there.
Jon,
J Sid,
Jon,
J Sid,
