Discuss Tiling behind and under a log burning stove in the Canada Tile Advice area at TilersForums.com.
248
Broughty Ferry, Dundee
Hi,
I have been asked to tile under and behind a log burning stove...
I am happy with the hearth, it is a concrete plinth that I can tile directly onto but the problem for me is the back panel behind the stove.
The board that is there at the moment is very flexible which I have told them cannot be tiled onto...
Would you remove the panel and replace it? - With what???
Can you screw another fireproof/heatproof panel onto the current panel and then tile onto that?
Cheers in advance
Stephen
Time's Ran Out
Is that fireplace staying? What's that made of?
MDF!
Is there not a recess behind that board for the stove to go into?
What happens with the flue or isn’t there one?
Is it going to work or is it just for show?
Boggs
1,118
Uk
What is the back panel made of?
Who has installed the stove?
248
Not entirely sure what the back panel is made of or who installed the stove.
My thinking at the moment it to remove the current flexible boarding and install 12mm Hardiebacker with a frame if necessary to provide a stable area to tile onto
WetSaw
Hardie is OK but I wouldn't be happy with that fireplace. Get something in writing stating that you are only responsible for the tiling, not fitting the stove.
Boggs
1,118
Uk
There is no way that fire is installed correctly.
It looks like that has been cobbled into an old gas fire surround, the flues are not compatable
and rear flies should have a maximum of 6” of horizontal glue before a bend, that definatley looks longer from your photo.
Solid flued appliances must only be installed by a Hetas registered engineer and can be just as dangerous as gas appliances.
I would not touch it at all.
WetSaw
It doesn't have to be installed by a HETAS registered person but does come under building control so would need signing off.
Boggs
1,118
Uk
In some areas building control won’t sign installations off without a Hetas certificate.
Boggs
1,118
Uk
100% correct, but first hand experience of BC not signing off one I installed because I didn’t have a Hetas certificate because they were not sufficiently qualified to sign off themselves.
Daft I know.
Reply to Tiling behind and under a log burning stove in the Canada Tile Advice area at TilersForums.com
  • Poll
Tiling behind and under a log burning stove > Tiling Advice - Tilers Forums
248
Hi,
Cheers in advance
Stephen
Time's Ran Out
MDF!
Boggs
1,118
Uk
248
WetSaw
Boggs
1,118
Uk
WetSaw
Boggs
1,118
Uk
Boggs
1,118
Uk
Daft I know.
  • Poll
