johnplum
What's wrong with this following system that I can't help considering?
- I'm starting with recently laid solid and level 18mm wbp over suspended timber floor joists which comprises a bathroom floor. This ply replaced floor boards in bad condition. Area about 4 sq m
- A shower tray former if 900 x 800, rises 8mm above ply.
- the idea is to tape ply joints and apply liquid tanking membrane over the whole ply area and also up rendered shower area walls, before following by laying down on the floor 6mm Hardiebacker board with thinset bed of 3mm to fill voids, and seal with taped joints.
- finish floor with bal SPF (6mm) and 10mm granite tiles.
Usually the liquid membrane is applied over ply before direct tiling, or over tile backer - though Hardiebacker have said, I read, they don't recommend liquid tanking over their board.
I could have simply used 25mm ply and tiled directly.
The idea I had is that as SPF is only water resistant, and as ply may go mouldy etc, the tanking of a small bathroom floor under the tile backer is ideal.
Critical comments and advice welcome!
