Currently reading:
Tanking floor - ply, liquid membrane, tile backer?
Discuss Tanking floor - ply, liquid membrane, tile backer? in the Australia Tiling Forum area at TilersForums.com.
johnplum
What's wrong with this following system that I can't help considering?
- I'm starting with recently laid solid and level 18mm wbp over suspended timber floor joists which comprises a bathroom floor. This ply replaced floor boards in bad condition. Area about 4 sq m
- A shower tray former if 900 x 800, rises 8mm above ply.
- the idea is to tape ply joints and apply liquid tanking membrane over the whole ply area and also up rendered shower area walls, before following by laying down on the floor 6mm Hardiebacker board with thinset bed of 3mm to fill voids, and seal with taped joints.
- finish floor with bal SPF (6mm) and 10mm granite tiles.
Usually the liquid membrane is applied over ply before direct tiling, or over tile backer - though Hardiebacker have said, I read, they don't recommend liquid tanking over their board.
I could have simply used 25mm ply and tiled directly.
The idea I had is that as SPF is only water resistant, and as ply may go mouldy etc, the tanking of a small bathroom floor under the tile backer is ideal.
Critical comments and advice welcome! :)
Dave
Subscribed
389,894
1,000,000
Co.Durham
Why not over board the floor with a cement faced poly core board like marmox ?
Tape joints and perimeter floor to wall transitions and fixing points with correct tanking tape , no issues then .
then you can either liquid tank walls or use membrane tanking . Following same suit as floor for joints .
johnplum
Yes I was considering that option, of a waterproof insulation board with cement facing.
I have the liquid membrane, enough of it. In a way this is constructing my own waterproof cement-faced board.
I bought the Hardiebacker, but could return it, I was told; hence I'm asking the question.
Would this idea not be comparably as good in terms of water resistance? AN interesting comparison, methinks at this time.
I'm not absolutely confident in extruded polystyrene (XPS) degrading faster over a score + of years. XPS may be better for walls than floors, with the impact of feet.
I haven't been able to see the Marmox board myself (I would have to try harder). I see its a comparable price to Hardiebacker.
Dave
Subscribed
389,894
1,000,000
Co.Durham
I'm not absolutely confident in extruded polystyrene (XPS) degrading faster over a score + of years. Hardiebacker may be better for walls than floors, with the impact of feet.
if you tank the floor first then hardibacker , the fixings at basically every 200mm will puncture that water tight membrane. Water could then permeate at those fixing points and seen as hardi do not recommend tanking on top , how would you over come that .?
the other alternative as you have the hardi is to use a sheet tanking membrane over the hardi adhered with SPF adhesive. Again taping joints et .
johnplum
@David: Good point about the screw fixings to the tile backer. SO a sheet membrane is a good idea :thumbsup: Screw fixings are a weak point for water penetration through any tile backer or insulation board - bitumen sheet would be superior for waterproofing.
:detective: This raises the question , why use a tile backer on a floor anyway over ply?
- a sheet membrane would also lose any advantage of tiling to a backer board, which is the reason given by Hardiebacker, for not tanking with liquid butyl etc. Perhaps they're wrong - that stuff is very sticky, and you're supposed to tile over it., in which case,
:2guns:Perhaps there is no good case for using tile backer board over ply flooring when tanking?
If so, I could simply screed the floor with a mix of my choice, apply liquid tanking and then tile over SPF.
johnplum
@Ajax that's good advice, and a useful reminder, as I juggle with ideas... It's easy to overlook that, as I've not seen it mentioned on company 'how to's' It's what I do with bitumen and render, with sharp sand.
Speaking of which, I'm considering applying bitumen as a sealer to the ply, whatever I use to raise the ply floor level - screed or tile backer.
Comments on structural consideration still welcome.
Should I screed or use tile backer and, if so, should I apply liquid membrane to the tile backer, or is sheet better, or apply nothing, relying on liquid bitumen on ply?
Bearing in mind the shower area has a waterproof tray former, in a small bathroom.
johnplum
Reflecting a bit more on the choice, I think Hardiebacker could be wrong to advise not to tank their cement board, adding that their board soaks up any moisture without deforming. Major waterproofing companies (e.g. DUnlop, Everbuild…) produce their liquid membrane specifically for tiling over, and list compressed fibre-cement sheet flooring as a suitable substrate.
A tanking membrane makes cement board redundant for wet floors, and a good screed is sufficient. Also, means you don't have to use extra fixings, tape, and adhesive bed.
Nomoreply state that their product is to go over ply flooring in bathrooms and save it from becoming damp: But, that's not considering tanking with liquid or membrane.
Dave
Subscribed
389,894
1,000,000
Co.Durham
i agree , apart from 18mm ply IMHO isn't sufficient regarding strength , my choice would be 25mm min , tanked with a sheet membrane .
but if you have already installed 18mm as said in your OP, then advice was given on that scenario as I see it .
others might differ and you take from a thread which way you want to proceed.
johnplum
Why not use 6mm insulation boards and tank over the top, then tile ?
I'd like to keep it simple, and simplest most natural materials if possible. :mad2:
Personally, I think we be better off with downstairs baths or showers on a 2 square metre stone slab with a ceramic gutter complete surround - have a suspended decking walkway in winter for warmth. Easier to maintain and build. OK for wheelchair access if its a shower. And also, separate rooms for toilets! :smilewinkgrin:
One reason for not using insulation boards (a 'floating floor) is I think, that insulation is redundant on a suspended timber floor - timber is insulation. Maybe insulation boards are useful on a concrete floor. I could insulate it and add underfloor heating, as many are doing. I don't see the point in insulating it and then heating a suspended timber floor, when I can just let warm air rise from below and gently warm the floor. Wow!
Chalker
1,058
Tadcaster
I suggested insulation boards ( marmox etc) to build up the 6mm difference, and because they are waterproof and can easily be tanked. Which as a wet room it needs to be tanked . I always lay them with SPF , then screw. This is not a floating floor.:thumbsup:
johnplum
Well, after this conversation, which guided my thought, I am clear on this now. It takes a while to think this , I needed to think, think again and sleep on it too, with all the options and claims.
I'm going to remove the 18mm ply, replace with 25mm, and tank otver that.
AS for bitumen sheet, I do fancy that, always did. It seems very expensive to me… perhaps I might find a cheaper supplier. WHich leaves me with a final question: :hurray:
I highly rate bitumen sheet and liquid bitumen from my building experience, so how does liquid bitumen compare to bitumen sheet as a tanking membrane? Would liquid bitumen and bitumen tape for seams be as good a solution as sheet, or not? Anyway, would liquid bitumen not be better for the walls?
A related question, How does liquid bitumen (applied in two or three coats) compare with liquid butyl compounds, commonly found sold as tanking solutions? None seem to use that.
Cheers, John
Reply to Tanking floor - ply, liquid membrane, tile backer? in the Australia Tiling Forum area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber floor in our barn conversion. The area is large, 21m x 8m. Having spoken to various UFH suppliers I...
