Seal-Guard
  • Thread starter Thread starter tony TLC
  • Start date Start date
  • Tags Tags
    usa
tony TLC
seal guard aerosol grout and tile sealer
wow what an amazing product just spray and go
saw it in action today and it does what it says on the tin easy floor sealing demo i saw was a quick spray on traventine then coffee put on it and just beaded on the tile this was in a matter of about 1 min .
also you can use it on 20min dry grout(yes still damp) all i can say is this product is for me
SEAL-GUARD
tony tlc:coffee:
£28 seems expensive but it is very good - at least the demo i saw yesterday was. Not sure how long it would last once applied.
This is an old post.......................
I seen a demo....... bit of kitchen roll top half sprayed with seal guard then water run over the bit of kitchen roll.Water ran off the top part...... the bottom part got soaked and started to rip...............Good stuff i've got a 1litre tin has to be applied way a brush
I used this and to be honest didn't think much of it.
You are advised to ensure good ventilation when using the aerosol spray - a bit difficult in small bathrooms. I would strongly recommend a respirator when using the spray. Maybe the tin would be better.
Seal-Guard
Tags Tags
usa
tony TLC,
frogeye,
tony TLC,
frogeye,
