Guest viewing is limited
Removing Tiles Laid On No More Ply
Butch
I need to remove a few porcelain tiles laid over no more ply on wooden flloring using mapei adhesive so as to gain access to some onder-floor services. Any tips on the best way to achieve this? Thanks for any help.
Butch
When I remove floor tiles, I disc cut down the grout joints carefully but use a Hoover to catch the dust, then starting at one corner break it out with a hammer and chisel.
I rake grout out using a stanley blade, smash tile with round edge of my hammer slowly and then use hammer and chisel slowly
Thanks for yor help, StevieBoy
If possible, go in from the ceiling underneath, it'll be loads cheaper to patch a ceiling than repair the floor.
Thanks for the reply, Bri. Unfortunately it is a ground floor kitchen with no access under the floor.
Butch
Getting the tile up off nmp is ok. It's getting the NMP off wooden flooring that's the nightmare lol
@Butch how did you get in mate
Had to remove two tiles (one at each end of the cable run). Took a while to cut through the grout. Then removed a corner off the first tile (carefully with a small ball-pein hammer) and then managed to eventually chisel up the tile. The other was more difficult. In the end I simply cut down through the grout line and into the floor board around the tile edge so that I could remove it (I needed access underneath the floor anyway). Job now done and new tiles re-instated. Thanks to everyone who made helpful suggestions.
Butch
Butch,
Butch,
Butch,
Butch,
