No more ply ?????
Deleted member 5518
Hi all,
i am due to start a job this week laying 450 x 450 ceramics onto a wooden floor and was wondering if anybody has used "No more ply"
It's 14sqm and wanted to know if its easy to use and speeds up the job as i have only used ply before which will work out quite a bit more to the client
kind regards
Neil
Floor2wall
It is fine to use, be careful when handling though as the boards can be dameged easily in transport. using the NMP Mega strength Adhesive with a caulking gun apply a few beads as per the instructions and lay on a clean floor then fasten down with the NMP screws.
I use a lot of it and i feel its great for my way of working, others will prefer the Hardibacker method of boards fixed with cement based floor tile adhesive. Only if the t&G boards were badly cupped would i opt for this method though.
http://www.nomoreply.com/pdf_files/no_more_ply_01.pdf
What he said :thumbsup:
Yeah,great stuff go for it just be carefull of running out of nmp glue ,think they say you can get 7 boards stuck down with a single tube,you have to use a small bead to achive that though.
No more ply ?????
UK Tiling Forum; UK
Deleted member 5518,
Billy Hunt,
Billy Hunt,
