New Member from Rugby
billigmeister
Hi all - thought i would say hello.
Good site for advice.
Am not a big diy-er but have started to get into it more.
Am thinking about doing a simple bit of tiling around a new bath being fitted. Just trying to get as much information as possible before deciding whether to undertake myself.
Having a new bath installed and was thinking of doing the tiling myself (pretty much doing the length and the width of the bath upto ceiling height). probably 5.5sqm at tops withough any strange cutting or obstacles.
one main question i have is - is it best to tile directly off the bath after that is fitted or could i put a batten across and tile off that and then put the bath up against and seal it afterwards?
welcome to the forum
fit bath 1st , centre wall between bath and ceiling , run datum line round check cuts to bath and ceiling, you dont want unsightly cuts, i wouldent go full tile of bath , they may appear level but they tend to dip a bit , and you dont want a a big gap between bath and 1st tile, also centre wall width wise as well
billigmeister,
Ian,
billigmeister,
Ian,
