Due to my recent moment of stupidity I'm in need of some new levels I've just ordered a set of stabila ones 600 1200 1800 for £80 but ill need another set who's uses what ?
hahaha beat me to it!Solo.......SOLA
Why do you need 2 sets of levels ?
Try this for value ........ linkyDue to my recent moment of stupidity I'm in need of some new levels I've just ordered a set of stabila ones 600 1200 1800 for £80 but ill need another set who's uses what ?
@smudger85 have you not got a self levelling laser?Stabila 196-2. Got a 60cm,100cm. Cracking levels in my opinion. Robust and I find the non slip red end caps quite useful. Stops the level slipping down the wall when drawing lines around the room.
but he tells me it's to much messing about with tripods etc.....ahah thou say to him. dead. of. hunger!!!. saying: antonio, the Italian said. LolNo to be honest. The guy I'm learning from doesn't use one.
Am I stuck in the dark ages drawing lines around the room then?
I have mentioned using a laser level but he tells me it's to much messing about with tripods etc.
Bravo 😉Haha I hear what your saying Antonio,the Italian😉
Yeah I've got the 360 dewalt green beam one but I still like having a level to check horizontal and vertical and flatness as I work@smudger85 have you not got a self levelling laser?
sameYeah I've got the 360 dewalt green beam one but I still like having a level to check horizontal and vertical and flatness as I work
Your mentor should take my avatar, infact I'm gonna change it after reading that 😉
If you can afford it buy one of these, this is the dogs dangles
DEWALT DCE089 GREEN 360 CROSS LINE LASER WITH 10.8V 2.0AH BATTERY - http://www.toucantools.co.uk/dewalt_dce089_green_360_cross_line_laser_with_10_8v_2_0ah_battery.html?source=googlebase&kw=pla-223268308838&fl=1000&ci=55752835838&network=pla&gclid=CjwKEAjw7ZHABRCTr_DV4_ejvgQSJACr-Ycw2En8MD-h8PJOLphdWICQEfr8ZIYVDXHDtJyYcHa0cBoCVpzw_wcB
If thats too steep then even get one of these
DEWALT DW088K - https://www.howetools.co.uk/dewalt-dw088k-disposable-battery-cross-line-laser?utm_source=google_shopping&gclid=CjwKEAjw7ZHABRCTr_DV4_ejvgQSJACr-Ycwz5pVtt8NPSX2-mSZ0Atns9p3_NTqMQNOqY7iSmcZMBoC9kHw_wcB
Either of these will change your working life forever and neither need a tripod. There's magnets to stick to plasters beads etc or a simple nail in the wall will allow the adjustable bracket to give you an anchor.
I cant imagine going to work without one now 🙂
Yes of course I still use levels for things like that, but I was just advising Smudget to get the laser level for the obvious benifits of accuracy and speed of setting out.Yeah I've got the 360 dewalt green beam one but I still like having a level to check horizontal and vertical and flatness as I work
Same as Lee Mac, laser level was one of the best things I ever bought! I got the Dewalt DW089K
DeWalt DW089K 3 Way Self-Levelling Multi Line Laser - http://www.ffx.co.uk/tools/product/Dewalt-Dw089K-5035048338599-3-Way-Self-Levelling-Multi-Line-Laser
Sometime you can get it for under £200 from amazon warehouse.
Thanks for the link. Think I'm going to bite the bullet and go for the green laser at some point. Although it's twice the price I think I'm going to bite the bullet and go for the green dewalt laser at some point soon.
Is there an echo in here 🙄
why not just clean them when adhesive gets on the levels?I use a Bosch laser level and the extendable pole, few years old but works fine.
When it comes to spirit levels i just get the drop forge sets when needed when on offer at screwdix, all ways check them for level, and allways get the 90cm level seperately.
They allways get covered in addy and after a while are hard to read.
Buy cheap and often in my opinion.
