Discuss Internal Corners (again!) in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I've seen lots of posts on internal corners in a bathroom but am still confused as to what to do and I apologise for not getting it. I am tiling a bathroom wall and have got to the internal corners. From what I understand the two tiles will overlap and that a gap of 2mm should be used (ebtween the tiles I presume?). But on the first wall should I grout the corner and then on the second wall where the tile overlaps do I grout and then apply sealant on top?
Or should I not be using grout at all and just fill the gaps with sealant to enable a bit of flexibility?
Really appreciate any help on this and thanks in advance.
eddcottee
You dont need to be forcing it right down into the joint at all. The gap is there to allow for expansion movement. The silicone is a sealant and stops the water from getting into that gap.
Reply to Internal Corners (again!) in the Canada area at TilersForums.com
laattaana
