Discuss insulation boards in the Tiling on Underfloor Heating area at TilersForums.com.
mike1979
hi all I have a concrete floor to tile with electric heating and 10mm slate I have seen these boards called xp pro insulation boards I usually use the insulated tile backerboards has anyone used these boards and advise me cheers
mike1979
ok great so if I do the usual flexy adhesive to lay them in fit the underfloor heating fibre reinforced self leveller on top and tile away as normal it should be fine ? I always use backer boards but if these do the job the customer will save around 300 quid
J Sid
not should be, will be fine, just allow a bit of time to prime top and underside
like you say can be a big saving to
Uheat - Jake
TF Official Sponsor
743
Hello Mike,
The XPS Insulation board is a great saver if you have a concrete base.
We have the options of 6,10 & 20mm boards all which need to be stuck down with a Flexible Tile Adhesive.
Our boards have a 300kpa compressive strength so there not easily damaged when tiling. The boards also have an excellent U-Value.
The boards would need to be covered in the normal way of a Flexible self levelling compound over the top.
Reply to insulation boards in the Tiling on Underfloor Heating area at TilersForums.com
Hi, We are tiling our kitchen with limestone tiles - we have already done it in the hallway and...
