P
paul bovey
Hi there. I need a memory jog. Terracotta with 10 to 20mm joint. Ball wide joint or sand cement ratio.
Discuss Grouting Terracotta in the The Welcome Forum area at TilersForums.com.
Ok. Thanks. It's only 15m2Id go with the Bal - if it's not too big an area.
sand and cement grout will not last or wear as good as tile grout in my opinion unless you make the mix stronger. in my youth if I remember we used 9/13 for ceramics but that was many yrs ago and ones memory gets a bit cloudy
Reply to Grouting Terracotta in the The Welcome Forum area at TilersForums.com
