Discuss Grouting Terracotta in the The Welcome Forum area at TilersForums.com.
paul bovey
This is the ratios I very vaguely remember for grouting quarry tiles. After grouting we would chuck a dry mix of sand cement over . Like feeding the chickens. Then we would brush it in the wet joint to flush it up before we washing off. Overall I'm struggling to remember the ratios. I know it sounds mad but I swear it was 1.5 .1 or 2.1
White Room
You can do a strong mix with quarries due to their strength, terracotta would need a weaker mix due to the material...try using a 3-1 with sandstone, any movement will tear the sandstone apart IMO
paul bovey
Sorry . Don't quite get that. You put sand stone in the mix?
Time's Ran Out
It's possibly too late to check if the terracotta has been fully sealed before grouting.
Bal wide joint sandstone grout is always a safe bet but 3:1 of sand:cement is easy to wipe off a sealed surface.
Reply to Grouting Terracotta in the The Welcome Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
Hi all. As title suggests. Used to use this forum a while back but seems my account was deleted...
  • Poll
Hi, I have a small en-suite 1200 x 2400, with a 1200 x 900mm linear drain tray which will have...
