Expansion joint
U
Unregistered
Can any kind soul advise me on what options I have ! Im tiling a large floor area with a new 5 mm porcelain floor tile . Due to the size of the floor we have been advised to fit expansion joints .There appears to be no expansion joints that depth on the market !
Has anybody come across this hurdle ?
if you can't find a manufactured one of that depth you could use a silicon expansion joint in the grout lines where required. use a colour match silicon to your grout. bal and mapei have good ranges of these
Could be a bit tricky with a tile that thick,make sure edge of tile is well bedded but make sure you leave room for expansion
what about using two squared metal tile trims each side of the joint with a 4mm gap and just fill with Silicon
make sure you have allowed for expansion around the perimeter of the floor as well......
Expansion joint
Unregistered,
Diamond Pool Finishers,
Unregistered,
