Corner joint where two tiled walls meet
mmdowson
Hi again
What do you recommend to do at the corner joints between two tiled walls?
a. Use grout
b. Use a Silicon type
Mark
Hi Mark..
This joint is an expansion point and should be filled with a suitable sanitary Silicon... these can be bought in colours to match grout colours if required.
Cheers Dave
I have BAL manilla microban grout and Silicon sealant, so will just use the grout between the tiles and Silicon between corner joints and floor and walls then.
Cheers
Mark
mmdowson,
DHTiling,
mmdowson,
DHTiling,
