Discuss Can I recover from this unbelievable mistake in the DIY Tiling Forum area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
I set my first row of tiles on a level batten measured the center of the room on a wall with a large range and metal splash back. I then tiled to the left and right of the splash back and down the sides. When I started the next day and stared tiling the second row I found the one of the tiles on the first row was not a full tile (9.9 cm instead of 10 cm). To remove all the tiles and start again was going to cause too much damage so I just cut the row 2 tile above the bad one to be the same length. You can hardly notice the "bad join" but I know it's there. Is there any way I can hide that bad "cut" join. I attach a drawing that may help explain what I mean. I know this is an absolute amateur mistake so any help would be appreciated.
  • tile problem.pdf
Lou
Admin
Staff member
Oh dear, if you take a photo with your phone if you can then up can attach it onto here using the box that says attach file.
Lou
Admin
Staff member
It just helps the members get more of an idea how to advise you best.
Reply to Can I recover from this unbelievable mistake in the DIY Tiling Forum area at TilersForums.com
Dawz84
