Discuss bal flex bone 2 easy in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
One Day
About the same £10+ equivalent in the US.
Too expensive for too little benefit I think (so far).
widler
It’s £12 plus vat if you buy loads , bloke on my job paid £200 for 10m2 , he was trying it on a floor before he did the rest , 160 odd m2, he said it was too expensive and didn’t sound right to walk on compared to a little toilet I did in tm matting.
So he bought the tm matting, was cheaper to buy and lay than flex .
Apparently it’s been used for years like Harry said,so it must work though
H
hmtiling
I'm speaking to someone about getting it specced with warranty using the gutjahr branded one and a different adhesive . Bal are a company I refuse to line the pockets of.
Dumbo
Phone up bal tell them you got 3000m to do but the architect has spruced tilemaster adhesive , will you guarantee the mat . Bet you get a different answer .
Just Rizzle
ok guys so far a lot of what i already know. the job is 220 mtrs on a newly layed anhydrite floor that is going to be sanded 5 day after laying the tiles are 900 x 600 x 20mm limestone just bought the adhesive its webber rapid grey deal at ctd today. the screed will be 3 weeks old when laying. its going down next wednesday and no ufh
what im asking is has any one experince of laying it dose it sound hollow and is there any movement that may result in grout cracking
H
hmtiling
Are you using flexbone on this?
Just Rizzle
If your using flex bone, why are you sanding ? Also after 3 weeks it will still be too wet
were sanding to allow the hard layer on the surface to be removed as this will allow drying to happen quicker were running 4 big fans 24hrs a day to circulate the air so allowing drying faster.
the hard surface layer slows down drying as it helps retain the moisture.
Reply to bal flex bone 2 easy in the Adhesive and Grout area at TilersForums.com
Finias Coroama
