BAL bal flex bone 2 easy
I'm speaking to someone about getting it specced with warranty using the gutjahr branded one and a different adhesive . Bal are a company I refuse to line the pockets of.
Phone up bal tell them you got 3000m to do but the architect has spruced tilemaster adhesive , will you guarantee the mat . Bet you get a different answer .
ok guys so far a lot of what i already know. the job is 220 mtrs on a newly layed anhydrite floor that is going to be sanded 5 day after laying the tiles are 900 x 600 x 20mm limestone just bought the adhesive its webber rapid grey deal at ctd today. the screed will be 3 weeks old when laying. its going down next wednesday and no ufh
what im asking is has any one experince of laying it dose it sound hollow and is there any movement that may result in grout cracking
Are you using flexbone on this?
If your using flex bone, why are you sanding ? Also after 3 weeks it will still be too wet
were sanding to allow the hard layer on the surface to be removed as this will allow drying to happen quicker were running 4 big fans 24hrs a day to circulate the air so allowing drying faster.
the hard surface layer slows down drying as it helps retain the moisture.
BAL
Just Rizzle,
macten,
Just Rizzle,
macten,
