Discuss 1200mm by 600mm porcelain tiles. in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Hi guys. Just picked up a job with 1200mm by 600 mm wall tiles. As this is the first time Ive had tiles this size is there any advice or pitfalls I should be worried about? Ive installed a lot of 600 by 600 wall tiles with no problems. Any tips would be gratefully received.
Hi mate,
I'd turn the job down. Stupid size, which will definitely have a bow in them, so you'll be attempting to lift a very heavy and no doubt rectified edge tile off a wall that isn't flat enough, and then you'll have to take it off again. And once more when the next one goes on. By this time, you'll have taken a tooth out your mate (hopefully you have help), or a chunk out of the tile or the ceiling/door.
Forget it mate. Stupid designers sat in the offices think these are okay for bathroom walls. They are crazy.
Save them for an airport floor.
Andrew Owens
I did some before Christmas, I bought and extra sigma suction cup to handle them, I had trouble cutting less than 20mm on my large Sigma so I had to use my grinder. Back butter with a 4 - 6 mm trowel. Lots of leveling clips and prep and everything will be ok.
Hi guys. Thanks for all the help regarding these tiles. Despite my reservations I took the job on and managed to make a pretty good job of it. All cuts were done by hand using my grinder and a blue Rubi blade on masking taped lines. As Huddersfield Tiling said I paid attention to bowing but only found one bad one. However, despite my success, I won't ever be doing another bathroom using this size of tile. And they want three more bathrooms done as well. Not for me.
Reply to 1200mm by 600mm porcelain tiles. in the Canada area at TilersForums.com
Apatel
