10mm sq or 20mm crescent?
P
Prem Tiler
Which trowel will leave a higher adhesive bed between a 10mm sq notched and a 20mm half crescent?
in theroy, they should do the same job!
but i find a half round gives better coverage!
to be fair i start with 1 trowel, if the bed is not perfect, i move up a trowel.
but if i have done the plastering i use a 6mm square notch on walls
and on floors i always use a 20x10mm floor trowel.
Dagger.
Same as the others on the floor trowel Dean but on walls I normally use a 6mm Square notch for ceramics and a 8mm for larger/heavier tiles..
Level it and you will get a better finish and less problems tiling. In a word "Preparation"
done already mc but I need to clear the sensor coax that i didn't chase out for ufh.
Aye right, I remember reading another thread where you mentioned that...:lol::lol:
No sweat mate, but can you still not chase the conduit in carefully now? If not I would still just level over again - just feather away over a 1m or so if your worried about using too much leveller:thumbsup:
use a "blunt" chisel, scrape carefully in a "safe..ish" area,
you only need a few mill, bury sensor, and cover over in duct tape,
use a floor trowel (20x10 round) and carry on as normal.
you wont be the first to forget the sensor... or the last,
its a problem because it dont come in the heat mat box, its with the thermostat...
ive done it, so i know how you feel.. chin up big man.
use a blunt chisel and scrape the slc, slowly! you will sort it!
Dagger.
Pourable thick bed is a pain dont u find the addy squeezes between the tiles
never found a problem with it maybe you mixed it to wet ?used over 700 ton in the last 10 months without a problem
Prem Tiler,
Perry,
Prem Tiler,
Perry,
