Discuss Does white tile adhesive have relatively weak bonding strength? in the Tile Adhesive / Grout Advice area at TilersForums.com.
yhchang
46
Taiwan
Hi,
Does anyone know why the bonding strength of white tile adhesive is weaker than normal(grey color) tile adhesive?
L
LM
I wonder how your national classifications compare to EN European or BS British standards? Under either of these the colour of the adhesive is irrelevant.
Dan
Admin
1,318
Staffordshire, UK
I wouldn't have thought white over grey matters from an adhesion point of view. I think it's less common and more expensive because of extra processes. But I wouldn't have thought those processes to remove and / or add colour change adhesion processes.
yhchang
46
Taiwan
In my country I heard this from some people in related industry. They said that white tile adhesive is made by white portland cement. And white portland cement strength is weaker than normal(grey) one. I am not sure if this is true.
[automerge]1575510208[/automerge]
It isn't to my knowledge, why do you think it does?
I heard that the strength of white portland cement is weaker than normal(grey) portland cement.
Dhtiling
463
Alaska
Not sure what adhesive you are using, but most here have a TDS that states bond strength, sheer strength and all other performance properties. I have never noticed there to be a difference due to color.
Ajax123
1,213
Lincolnshire
No difference between white and grey in terms of bond strength when directly compared under EN standards. There may be some brands that differ from others and some dont conform to EN standards which may be weaker or stronger.
Reply to Does white tile adhesive have relatively weak bonding strength? in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Poll
