Shower room large tiles. Where too start
Mhen
DIY Tiler
Hi,
I’m about to start a shower room job. I’m using 1200mm x200mm tiles vertically. So it will only be 2 high each row.
What’s the best way to start. If the tiles were smaller I would use a baton to get my level but wiith only 2 high, not sure the best way to start. Should I use a baton and put the top tile on first or should I try and get a level at floor level ( allowing for floor tiles) and do two at a time?
Any help would be appropriated
Tile the floor first and if the same tile run the cut from the floor up the wall as if the wall is an extension of the floor
Upvote 0
that looks good but we are using different tiles and different size so wouldnt work. thanks for replying.
[automerge]1569932682[/automerge]
Hi , run a level Datum line around the perimeter of your room, central ffrom floor to ceiling , then cut the first row to this datum line if that makes sense .. then continue with second row .
Thanks for the reply.
Yes i know what you mean. Will give that method a go i think. saves me trying to get a level baton 15mm off the floor. Cheers
Upvote 0
Those tiles are similar to yours . They have been fixed with a random bond that is why they look different to yours. Your tiles could be fixed in the same manner.
Upvote 0
Lay a the floor first and level. Fix tiles to the wall, full tile of floor (pretend it's a batton).
If your ceiling is 2400 high its 2 full tiles, if less you will need to cut top tiles to ceiling line
Upvote 0
Hi,
Hi,
how i use a laser level to ping a line round,, if you dont have access to one, use a level and draw a line all the way round, if the floor is tiled after wall then you dont need to be so accurate with cuts, with in a few mm as floor will cover, hope this helps a little
Upvote 0
Best Bathroom Tiles
Unsolved
Mhen,
bradley ogrady,
Mhen,
bradley ogrady,
