Discuss 135mm dry drill bit? in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com.
Wishiwasatoptiler
Hi Folks, need a drill bit 135mm or at most 140mm, struggling to find one, normally use ats dimond drills but searched there site and cant find one, its for porcelain,
Cheers
Concrete guy
We do a 125mm, then open up the remaining with nippers or a grinder, or a zero tolerance drum/finger bit.
Over 125mm is very unusual as a regular drill bit. You'll find them as a dry cores but they aren't exactly delicate or clean cutting.
Wishiwasatoptiler
The problem is, its to go round a pool light inspection cover, theres no cover, shroud to hide the cut tile, pool company say it it need to say in situ, so the edges need to super neat. I have the 125mm ats bit already, works a treat, but this is 135mm.
Concrete guy
Is this external 20mm porcelain?
If it is and this sounds like a one off, get it cut by a waterjet company.
Time's Ran Out
E2910596-3BD6-4A2A-8518-279C63795FDA.jpeg 735A011F-7670-46E0-806E-8D5CB194F58D.jpeg
Exactly as you require - hand cut using a grinder and pinchers - pool floor light. 60x60cm porcelain .
Reply to 135mm dry drill bit? in the Tiling Tools | Tile Tools - Tile Installing Tools area at TilersForums.com
Bob Marley
