Discuss Best adhesive for 200 x 500 x 8.5mm tiles in the Adhesive and Grout area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Jkb
Hi,
First post here and a real tiling novice. I plan on putting up some 200 x 500 x 8.5mm wall tiles in my bathroom but not sure on the best adhesive, some adhesives I have found say they are suitable for max 300 x 300mm, I take it it’s limited to do with the weight of each tile? Any advice please?
Boggs
You will need a cement based adhesive, I can highly recommend Tilemaster Standard Set Setaflex.
Steer clear of rapid set adhesives if you are a novice, you will throw away more than you use.
Jkb
Hi,
Thanks fir the replies above.
Because of my location, I am getting a £15 delivery cost on the above recommended item. Is there any similar item that b & q or Topps Tiles provide? Both have local stores.
Regards
Topps will do a white single part slow set flexible adhesive either bal or topps own brand
Reply to Best adhesive for 200 x 500 x 8.5mm tiles in the Adhesive and Grout area at TilersForums.com
Lowpaul22
