Best adhesive for 200 x 500 x 8.5mm tiles
Jkb
Hi,
First post here and a real tiling novice. I plan on putting up some 200 x 500 x 8.5mm wall tiles in my bathroom but not sure on the best adhesive, some adhesives I have found say they are suitable for max 300 x 300mm, I take it it’s limited to do with the weight of each tile? Any advice please?
You will need a cement based adhesive, I can highly recommend Tilemaster Standard Set Setaflex.
Steer clear of rapid set adhesives if you are a novice, you will throw away more than you use.
Hi,
Thanks fir the replies above.
Because of my location, I am getting a £15 delivery cost on the above recommended item. Is there any similar item that b & q or Topps Tiles provide? Both have local stores.
Regards
Topps will do a white single part slow set flexible adhesive either bal or topps own brand
Jkb,
WetSaw,
Jkb,
WetSaw,
