Discuss 1200x600x10mm porc on walls in the Canada Tile Advice area at TilersForums.com.
First image, Garythetiler, myself and a bit of Mark, (whitebeam)
This is what you want to see, no serrations as such, bearing in mind it wasn’t 100% bedded, wouldn’t have been able to lift it otherwise.
Second image, what you don’t want to see, a ptb was used and it clearly slumps away , leaving areas with no adhesive at all.
You get the idea.
8492C053-49D2-4A74-9BB4-BBA7B09B1B15.jpeg 0581D2BC-6541-43F7-9776-7EFF93D03027.jpeg
Both would of worked if lined up your notches perfectly. In fact if you let it go of first you can just slot them together . I call this dry solid bed fixing
Waluigi
Either my eyes are starting to go or those shots were taken with Johns Pin Hole camera.
Blunt Tool
You get the idea.
View attachment 105037 View attachment 105038
You forgot to blur your face I can’t unsee it now!
Blunt Tool
You get the idea.
It’s a wonder you got that tile up without breaking it
Reply to 1200x600x10mm porc on walls in the Canada Tile Advice area at TilersForums.com
  • Poll
