Tool modifications - post your tips here .......
What I have noticed in the past when putting levelling compound in fairly thick is that when running a spike roller through it can push some of the levelling along in front of the roller like a bow wave . I guesed this is to do with the spikes being to close together so today i took an old spike rollet apart and broke the centre out of half the spike rings and put itback together with half the spikes only . Got to say it work a treat .
I did not understand what you did ...
but it does not matter....
the thread is ok 🙂
I removed every other row of spikes from my spike roller
I almost understood,
but the photos help.
I had this happen to me only yesterday!
Will strip mine down and have a go on the next one.
Dragging the slc with spike roller normally happens if you try to move it too quickly in my experience.
Or if it’s starting to go off.
I fully understand your problem, if your using it on a deep pour say 20mm, it's so thick that the roller drags instead of rolls. I've took a few off my roller but at the ends to help it spin more freely .
Def not going off and yes I agree on speed . It was a 2 part so correct ratios and i did slow it down and still had bow wave effect but not so bad .
I’ve turned my Smaller, older Sigma 2b3 from a pull cutter to a push cutter by simply taking the handle off and turning it. Now push into measure bar as you would with a Rubi, works a treat as I don’t have the strength in wrists and painful nowadays
i used to buy those crappy gauging trowels, that have the handle welded to the blade, after one fell apart a couple of weeks after buying, i bought a smaller style marshalltown brickies trowel cost me £40 😱 and cut about 4" off the point that was a year ago and i've abused it constantly and it's still as good as the day i bought it, almost
Cut down a BAL grout mixing tub and a 50mm hole in the top. You can ease the guard through it.
30mm hole at an angle on the side for the vac hose.
Plenty of duct tape and it works so well I didn't wear a mask!
Far better than this that I bought:
Dumbo,
One Day,
Dumbo,
One Day,
