Discuss Cement board screws? in the Canada Tile Advice area at TilersForums.com.
Hi, just a quick question. What screws should I use/you use on new cement boards in the bathroom before tiling? The Hardie screws are not that great I'm told, do you have any links to screws good for mounting the panels to the wall.
macten
4.5 heads and 25mm for 6mm boards on floor.
4.5 heads by 35mm+ for walls if going into studs
Tommcd
Also now only use turbo gold from scrwfix. Originally used drywall screws but they are so hard to countersink compared to the turbo gold screws
Reply to Cement board screws? in the Canada Tile Advice area at TilersForums.com
